sub placement
Old Nov 1, 2004 | 08:51 PM
rideblue450's Avatar
sub placement
i have a 2000 F150 XLT 4x4, extended cab, and i was wondering if anyone has any suggestions as to where to put two subs in the truck, i use the back frequently so im stuck.
thanks for any help
Old Nov 2, 2004 | 01:08 PM
jeffrop's Avatar
I have a 1999 F150 SC 4X4 and am in the same boat as you. I broke down and bought matching OEM bucket seats from the local junkyard, swapped out the 40/60 bench seat.
Now I have a big open spot for a custom subwoofer enclosure between the front seats. I have 2 amps that will both be installed under the rear bench(can't flip open all the way anymore though).
Hope that gives you some ideas.
Old Nov 2, 2004 | 03:50 PM
brown0617's Avatar
rideblue -
I have a 99 SCab. I bought a box for my 2 8" subs from www.subbox.net that fit under my back seat with a 2" lift that is included.
I have since assembled a board with 2 amps, 4 crossovers, 1 capacitor, and distribution blocks. I mounted the board to the top of the box. I plan on fabricating a couple of 6" lifts using 2x6 rect aluminum tubing after I finish chasing bambi through the woods.
Old Nov 2, 2004 | 06:16 PM
this helps alot, thanks guys and good luck with all of your projects
Old Nov 8, 2004 | 01:27 PM
jeffrop's Avatar
I've almost got my subwoofer box done. I'll post some pics later today.
Old Nov 8, 2004 | 09:29 PM
PROAUDIO's Avatar
boxes
proboxrocks.com will lead you the right direction.hope this helps!
