jl
Originally posted by chillindude010
If you put a jl wo in your truck in the next few days let me know how it sounds. ...
The original plan was to put a 10w0 in the truck and put the 2 Premiers I have in my car, but I started leaning away from that because I only have 8 guage running in the car and that is not big enough to push watts those 2 Premiers want to be able to be heard in the car, and I don't feel like running any thicker.
Originally posted by sdf150guy
Anyone with 02's where are you putting your jack?
I hope Im goin to feel the thump from that jl 10 wo in the truck.
still tryin to decide on what Im going to put in the box. Does the jl wo 10 thump inside the truck or is it barely heard. I have infinity references in the doors. I will try to run as much power probably from 150 to 200 to it with a mono rockford amp. what do yall think.
Still can't answer if the 10w0 thumps in our trucks. I can tell you that 150w rms is slightly over it's limit, but it should handle it and 200w rms is to much for that sub.
When you say thump, do you mean you hear the sub nice and loud, or the sub hits hard enough that your insides feel it?
This what I'm running right now:
Honestly I wish I had more then 100w rms going to it. I used to have a single 12" version in my old truck with 350w rms to it, and I felt that thing hit in my chest.
Still up in the air about using the 10w0 though, it's power ratings is closer to my amp, but I love the Premier ....
If you want to use 150w - 200w rms, you may want to look into another sub though. Maybe a higher end JL.
The 3001 puts out 300rms, way to much for one.
Unless you are puttin 2 in-perfect then.
If you went with that amp and one w0, you would have to get a 2 ohm and just stick it on one channel(150rms @ 2 ohms)
Hey, I have a 02 SCREW with 2 rockford fosgate punch stage 2 10" s behind the rear seat. I chose the behind-the-seat box because i wanted my amp rack under the seat. The box is 5.75 " deep and has .65 c.f. per sub. I had to tighten my mirror to avoid adjusting it every other song. If you go jl, go with the w1's, I think the depth is the same and you'll get a better product. Goto www.subbox.net and they have a list of subs for small sealed boxes. Check it out just to see what else you can put in your box.
GOOD LUCK.
Rockafella..
GOOD LUCK.
Rockafella..
A single jl audio 10 wo sounds awesome with the rockford p3001 in the supercrew box. I highly suggest it if you are looking for some decent bass in the cab.
Now I'm gonna have to rewire and build larger boxes .....
