lookin for some bass
Old Jun 1, 2004 | 09:20 AM
Sn0wMan's Avatar
Question lookin for some bass
I have a 94 regular cab with a bench seat and im lookin into getting some subs and an amp (around 300-400$). Im not sure on what to get and i havent had any experience with subs/amps.
I need some opinions on what to do, and would appreciate any help.
Old Jun 1, 2004 | 06:19 PM
cgorris's Avatar
For a reg cab I would look at getting 2 RE 8" subs and a box to fit behind the rear seat. RE=Resonant Engineering. Do a web search and you should be able to find them. They hit pretty hard, sound great and don't require tons of room. Any 8" subs would work for that matter but the aforementioned are probably the best for the money. I would give them about 300 watts RMS total and that should give you more than enough to satisfy your bass needs. If you can build your own box you could save a little bit there but if you can't then you can just get a prefabricated box that will do well for about $75-100. Your looking at a total price with wire kit for the amp probably just a touch over $400.
Old Jun 2, 2004 | 04:12 PM
Sn0wMan's Avatar
RE
Anyone know a good site to get RE subs?
Old Jun 2, 2004 | 04:27 PM
Dupuis's Avatar
Re: RE
http://visionaryaudio.com/
http://www.respl.com/flash_index.html You will have to call for prices. Phone # on the site.
Old Jun 2, 2004 | 06:49 PM
Winsurfer76's Avatar
Just ordered two RE8's for my own sub project. I got prices from visionary audio of $112 for two shipped. I also got a quote from RE for $111 for two shipped. Hope this helps.
Old Jun 3, 2004 | 05:40 PM
Sn0wMan's Avatar
depth?
What is the mounting depth and required box volume for the RE 8"s? thanks in advance
Old Jun 3, 2004 | 06:02 PM
Dupuis's Avatar
Re: depth?
Just under 4''. Sealed is .217 and ported is .50. This is for each sub. RMS is 175 watts. They will do fine with anywhere from 80 watts to 200 watts.
Old Jun 4, 2004 | 03:40 PM
Sn0wMan's Avatar
Thanks for all the help, i appreciate it. One more question i have.... What kind of amp should i go with? Ive made up my mind and im going to get the two 8" RE subs since they have a low price and seem like they will fit pretty much anywhere (perfect for me).
Old Jun 4, 2004 | 04:34 PM
Dupuis's Avatar
Just get one that can around 150 watts x2 or 300 x 1 at what ever ohm the subs end up being. Mine were single 2 ohm. Good luck, you will enjoy them.
