Anyone put subs in SuperCrew?
2 8'' subs in custom box under rear seat. It goes all the way between seat brackets. The amp is mounted where the jack use to be. I mounted my jack in the engine conpartment. Look in my galley for pic. of the relocated jack. I should have the rest of the pic. of the sub box and amp soon.
Matt (M_Brandl_) has a sub box design for a 2001 available online. I have a similar design (based off of Matt's 2001 design) available for 2003 models.
Check out my gallery for the pics and info.
TonyPTX
TonyPTX
You might want to check out the following link. Quite a few people have bought enclosure from them and have nothing but good things to say.
http://www.supercrewsound.com/news.asp
i have 3 10" fosgate p3 subs in a custom box under the seat...had to remove all the brackets, but the box is a good support!
StealthBox
I bought a JL Stealth box to fit in the front console. I had the insides covered with dynomat to dampen any vibrations, and it sounds great. Install is clean, and it comes with a tray for inside the console so you still have functional storage.
For me, i wanted to make sure I could fold the rear sets all the way flat. With nothing under them, its not a problem.
JL Stealthbox
A JL Stealthbox sure is a good option for a clean install that doesn't steal any cargo space. The only "con" to the JL Stealthbox is that it will run you about $500-600 installed (w/o an amp). Add a decent amp to power the Stealthbox and you're looking at about $800 total for a JL Stealthbox installed.
In this case you're paying to keep your cargo area. A subwoofer enclosure of equal performance can be had for far less than $800 spend for a JL Stealthbox.
TonyPTX
TonyPTX
