Removable Stereo
Removable Stereo
I don't know if anybody had tried this... but its a thought.
Here is what I would like to do...
I want a subwoofer enclosure for 2 subwoofers with the sub amp between them. Ok, thats easy. Now, say I want to go racing and want to save some weight. I want the entire enclosure easily removed. I would like to simply disconnect the power, ground, and signal wires from the amp and pull the entire box out.
I know that the power wire and ground for my amp is very large. I would be hesitant to use something like banana plugs to make the connection "quick disconnectable". What would you recommend?
Here is some quick disconnects in 8,4 and 1 AGW.
http://www.partsexpress.com/webpage....7&WebPage_ID=3
Well the link didn't work.. but I found what you were talking about by going to www.partsexpress.com and searching for "quick disconnect". Thanks, that was what I was looking for.
