Focals and Qforms installed!
Old Jan 19, 2004 | 08:05 PM
Ricksta's Avatar
Smile Focals and Qforms installed!
Finally finished installing my Qform kick panels and 6.5 Focal Polykevlar components. Brrrrrrrrrr finished at sunset- outside 38 deg. and dropping! in West Central Georgia. I am upgrading from 5x7 Infinity Kappa's 572.5 ref. I've had less than 30 mins listening time as of this writing so here is my initial response. 1- large gain in mid bass, 2-highs remain equal(Infinity tweeter was very nice) 3-Much more headroom to crank.... if that's yo' thing. 4- soundstage/imaging is much better, near the center of the dash. Lesson learned so far- If you don't like to experiment just slap some QUALITY coaxials in the door and enjoy. Otherwise go for it and modify ! Amped Focals with a bridged US Acoustic 4ch.- 120 w rms x 2. I think some tweaking will get the imaging nailed. I don't think I can adjust my balance with my current amp setup but I'll research it more.
Ricksta
Old Jan 19, 2004 | 09:07 PM
bigrobrn's Avatar
Sweet. Thats a nice setup. Would like to see some pics of your final product.
What did you have to do to get the 6.5's to fit? Was is a big hassle?
Now I'm really thinking about getting me some kicks!!
Sounds like that is the way to go.
Old Jan 19, 2004 | 09:35 PM
cgorris's Avatar
Probably the most important thing you said
Glad your enjoying the kicks. I was sure you would, just takes quite a bit of playing around with them to get them just right.
Old Jan 20, 2004 | 06:36 AM
Ricksta's Avatar
Cool Qform/6.5 fitting
Bighorn- Not too much hassel fitting the 6.5's. Just place the speaker against the rear of the Qform and mark the holes with a Sharpie marker. Look where they are noting that you have enough clearance to accomadate the screw heads on the front of the Qform. I used the speaker gasket as a template on the front to trace the cutout, then removed it with a Dremel no sweat. Same with the tweets. Takes bout an hour for both pods from start to mounted.
Ricksta
