Stalls on acceleration ( loss of power)
Old 09-19-2018, 03:37 PM
Rubens auto's Avatar
2006 f150 4.2l 2WD rug idle rpm don’t go over 3700 even, after start the truck, start shakes. I have changed sparks plugs ( motorcraft), intake gaskets, fuel pump, intake manifold runner control, compression test is good ( 180 psi all six cylinders), engine exhaust pressure ok ( no restricted exhaust), injectors workings good. I don’t know what else to do. Any help I’ll really appreciate. Thanks.
Old 09-19-2018, 05:32 PM
Try replacing the wires and coil pack with Motorcraft only.
I'm sure it has codes if it's doing that. Please post the exact codes.
Old 09-19-2018, 08:32 PM
Are you SURE the cats aren't plugged?
Quick Reply: Stalls on acceleration ( loss of power)
