2001 harley edition supercrew axle swap?
I have a 2001 f150 harley davidson edition it has a 5.4 tritton in it eventually im planing on making it 4wd or (preferably) awd are there any expedition or other f150 axles, transfer case, and drive shafts i could use with my current motor and trans
All 97-03 4wd F150's and Expeditions regardless of model use the same front axle. Check your door jamb sticker for TRANS and AXLE codes and please post them. We need the axle code to determine the correct gear ratio.
You will need a transfer case, front driveshaft, and transmission out of a 4wd 97-03 F150 or Expy, there are 2 different transmissions and that's why we need your code. You will also need an appropriate rear driveshaft.
