bad lower ball joint?
hi I have a 1995 f150 xl 4x4 with an inline 6 and I've been have a rubbing issues on the front passenger sides on sharp turns. The truck is completely stock with 116000 miles and only rubs on that side. I was wondering if this could be a lower ball joint because I just replaced the driver side one (never had that problem on that side with rubbing) and it has at least 2 inches before it rubs. And feedback helps, thanks
ok thanks alot ill have to give that a try would u recommend that i remove the wheel
