Brakes squeak at start up and first few minutes only
Old 06-24-2010, 12:10 PM
Barrett's Avatar
Hey yall, so this has been going on with my truck for a while now and I just decided to post about it. My brakes squeak real high pitched when I first use them after I start up the truck. This happens for the first few minutes whenever I use them and then they seem to calm down and stop making noise. Any ideas why this is happening?
Thanks yall,
-Barrett
Old 06-24-2010, 10:07 PM
whitt91's Avatar
moisture from letting your truck sit for a second. my brakes did this also
Old 06-24-2010, 10:10 PM
buckshot85's Avatar
^^x3 i have new brakes and rotors and mine does this as well. doesn't last but down the driveway so not a big deal to me
Old 06-24-2010, 11:13 PM
Barrett's Avatar
Anyway to get it to stop?
Old 06-29-2010, 12:13 PM
mkinttrim's Avatar
Mine started doing this as well on the rear brakes only, seems to be ok when they are hot. It's definately NOT a moisture problem as it rarely rains and humidity is rarely over 20%. I'm running wagner thermo quiet pads all the way around. I changed my brakes fluid and took my pads off and didn't see any problems. I don't have a clue at this point.
Old 06-29-2010, 06:15 PM
mccrick's Avatar
Don't know if this is the same thing, I've got a 97 that started doing that this year. Took the calipers off and checked everything over; put a small amount of high-temp brake grease on the steel bar that the pads slide against when the piston pushes the pads. Stopped my squeak.
Old 06-30-2010, 09:29 AM
95'F-150's Avatar
Mine does this as well, except the rear drivers side wheel. I makes a real sharp squeel. But it's wierd if I apply the brakes hard it doesn't no it, only when I am barely on the brakes like driving thru a parking lot it squeeks a lot. Kinda drives me nuts, here I am with a nice lookin truck and the brakes sound like I'm driving a POS!
Old 11-21-2017, 02:22 PM
mhouston7's Avatar
wheels squeak.
So I get a loud squeaking noise from my front wheels when i start to go forward in the morning. And after i break and come to a complete stop. Its very loud and only after i stop and then start to go , never when im breaking do i hear it. It seems to go away after after a few stops. Once again it never squeals when i break only after i begin to go forward again and only for a few seconds but kinda loud. Any ideas?
Old 11-21-2017, 04:22 PM
No ideas whatsoever without more info on your truck...........
Old 11-21-2017, 04:52 PM
mhouston7's Avatar
2012 F150 64k miles on it factory brake pads never been changeg about 40% pads left what else do you need to know?
Old 11-21-2017, 05:20 PM
2wd or 4wd?
Old 11-21-2017, 05:32 PM
mhouston7's Avatar
2wd or 4wd?
2wd and seems to do it mostly in the morning and after a stop sign or two it seems to go away, but if it sits all day at work , the first cpl stops it does it again...and its louder then just a brake squeak and tapping the brakes stops it momentarily and it seems to be rotational with the tires if i speed up it goes away.
Old 11-21-2017, 06:19 PM
Make sure the pad wear scratchers aren't contacting the rotors. With 64k on the factory pads it's probably time for replacement.
Quick Reply: Brakes squeak at start up and first few minutes only
