Help Sirius Dead! Connect error see dealer
Old 01-13-2015, 07:56 AM
madmaxgt's Avatar
Hello,
2008 FX4 SC 4X4, Factory Nav, 6 Disk, SIRIUS Head unit. Original Owner.
Today I started the truck and began to drive to work. Pushed the SIRIUS button and the unit displayed "connect error - see dealer" at the top, and nothing else.
Every other feature works, SIRIUS account paid and up to date.
Any suggestions how to fix or "reboot"
Thanks...Max
Old 01-13-2015, 08:19 AM
MGDfan's Avatar
Originally Posted by madmaxgt
Hello,
Thanks...Max
If the following non-responsiveness is any indication, yall may need to just go visit the dealer ... no one here appears to have an answer ...
https://www.f150online.com/forums/mu...=connect+error
https://www.f150online.com/forums/sa...=connect+error
good luck
MGD
__________________________
*** Hey Karl65 - don't ye ever sleep? Start postin', son! Ye been lurkin' long 'nuff! ***
Old 01-13-2015, 05:12 PM
FordIVTteam's Avatar
Ford Customer Service
Hello,
Thanks...Max
Hey madmaxgt,
The best troubleshooting step I am able to recommend is called a master reset. Follow these steps: http://support.ford.com/sync-technol...ync-navigation
If you're still unable to connect to Sirus after trying that reset, reach out to the Sirius Support Center; they may have some other tricks up their sleeves. They can be reached at: 1-888-539-7474.
Kim
Old 02-20-2015, 07:46 PM
scoutmaster's Avatar
Sirius "Connect Error" w/ installed Factory Navigation
Did you ever get this resolved ... I was looking around and came up with the following when comparing harnesses ...
1 832 (LB-PK) Blue --- 22 CAN Bus +
2 * NC NC * Not Used
3 694 (BK-LG) Black Green 20 Ground
4 * NC NC * Not Used
5 856 (VT) Violet --- 22 Satellite radio left signal +
6 690 (GY) Gray --- 22 Satellite radio right signal +
7 833 (TN) Tan --- 22 CAN Bus -
8 * NC NC * Not Used
9 797 (LG-VT) Green Violet 20 Voltage supplied at all times
10 57 (BK) Black --- 20 Ground
11 798 (LG-RD) Gray Red 22 Satellite radio left signal -
12 799 (OG-BK) Orange Black 22 Satellite radio right signal -
Seems that the harness I purchased is missing the Ground in Pin 10 ... also there is an additional wire (taped back) .. Green with black tracer .... I haven't tried anything else ... I just contacted the vendor
Quick Reply: Help Sirius Dead! Connect error see dealer
