'04 F150 SIRIUS Tuner Install
[QUOTE=ieee_raider]I haven't seen anyone install like this, so I thought I'd post what I did in case anyone else wants to do the same.
I installed my SIRIUS satellite tuner where the 12V plug was. I don't really use the plug, plus there's an extra on the back of my center console in case I really need one.
Here are some pics:
Tuner:
Bracket:
QUOTE]
I would like to install my Spotster unit (mount looks the same) in the same way you did. Could you give me more details on the installation using the aux power on the dash location? How does the aux power (w/door) come out of the dash? I have access to it from behind, looking at it with the flashlight, but I can not see how it comes apart or how it comes out of there. Thanks for the help.
Here are some pics:
Tuner:
Bracket:
QUOTE]
Well, I think I actually broke a snap when getting it out. Just to see, I tried putting it back in and it was loose. It could be secured with glue from the back-side, though.
Anyway, I just pushed and twisted till it popped out, but like I say, I think I snapped something when it did pop out.
Good luck!
Good luck!
Good luck!
Good luck!
My Clarion tuner came with a mounting bracket that had a square base just a little larger than the round hole. I trimmed off the corners with my dremmel and it slid right in. I then screwed in the screws that would normally go in.
You could probably modify something like this: http://cgi.ebay.com/FLEXIBLE-GOOSENE...QQcmdZViewItem
I think my mount is the same one. I was also looking at trimming the corners so it would fit. Did you have to drill holes for the screws? I looked at the gooseneck mount, but I think the way you have yours looks cleaner. The only thing I'd change would be the cable routing, if possible, I would like to run the antenna, line out, and power lines below the mount and maybe through a hole (drilled) in the mount.
I didn't have to drill holes. They were already in the bracket, and I just screwed straight through into the plastic in the dash.
I had actually thought about going back and doing that but never found it worth my time since you can't see the wires really.
Thanks, that is what I thought.
