A/C problem!!!
I got a 98 F-150 and about 1 in 100 times I turn on the A/C after sitting for a while like 4 hours or more it makes a awful noise. The noise almost sounds like gears grinding and it only last for a couple of seconds. Is there anyway that the belt could make this noise? I checked the tension on the belt and I can push it down about half a inch so I don't know if thats bad or not since I'm not that mechanically inclined. I'd take it to the Ford dealer but I know I would just get the same old response "COULDN'T DUPLICATE" after the jerks have it for a couple of days.
The '99s have an automatic belt tensioner
I think '98s do also.
See if tensioner moves when you push on the belt.
Noise could be form tensioner.
Also could be A/C compressor clutch.
See if it does it when turning on air at different rpm's
Hope this helps
You may get better results posting in general discussion.
99 XLT 5.4l reg cab
4 wheel disc/ABS
5 star larait style wheels
Toreador red 2tone
3.55 gears
255/70/16 OWL
Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers (excellent sound)
Sherwood amp
subwoofer coming soon
More mods as funds become avalible.
[This message has been edited by 54regcab (edited 08-16-1999).]
Hope this helps
99 XLT 5.4l reg cab
4 wheel disc/ABS
Toreador red 2tone
3.55 gears
255/70/16 OWL
Delta toolbox
Sherwood amp
Thanks for replying man....I'll put it in the general discussion are as well.
