Drag Racing
Old 10-29-2006, 04:47 PM
Buck50's Avatar
ima try running my truck sometime this week.i'll get back you you guys on it. anybody else 0-60 around 8.5 or so. or am i slower then normal
Old 01-17-2007, 12:21 AM
Neal's Avatar
Cool
Originally Posted by quiktruk
Im running a 1988 f150 long bed. It has the 5.0, ford racing underdrive pulleys, MSD ignition, flowmaster exhaust, summit racing gear-drive, 4:30 gears, lakewood tracion bars, and a 100shot of nitrous. I havent done nething else to the engine, BONE STOCk, the key is timing.
Only made 1 run but didnt have enough nitrous, should have filled but before i went to the track.
Runs
60'- 2.100
1/8- 9.48
Speed- 71.08mph
Its pretty exciting staging next to a 5.0 mustang and being able to blow the doors of off it. I am ordering the edelbrock intake, heads, cam, and headers. I am also going to swap out the stock suspension and get some hoosier slicks, hopefully ill get into the 7's so i can add a role cage!!!
HI!... Those are some good times for your year truck. Your 9.48E.T in the 1/8 would be a 14.78E.T in the 1/4 mile.
I've got a "99" F-150, reg-cab, shortbox, stepside. Built 5.4 in N/A trim. Made 354RWH.P and 392RWTQ with 8.42:1 compression and NO tune. Last time to the track I ran 13.60E.T on 7 cylinders. Found out later I broke a compression ring in cylinder #5. On all 8 it should of run around a 13.1 - 13.2E.T. 60FT was 1.83 on NITTO drag radials. 0 - 60MPH is around 4.5 seconds.
Old 01-30-2007, 11:17 AM
BNCA1980's Avatar
I've never raced any of the fords i've owned, but I run my 02 Silverado, under it's current setup it ought to run 11.50's 1/4 mile on motor.
Old 01-30-2007, 10:48 PM
Buck50's Avatar
my 5.4 reg cab with just an intake did 15.9 at California speedway, is that good?
Old 01-31-2007, 06:19 PM
BNCA1980's Avatar
That's a respectable time for a stock pickup
My 02 Chevy Reg Cab 4.8 only ran 15.6's-16.0's in stock trim, and it was a light 2wd, so i'd be happy with 15.9!
Old 01-31-2007, 08:39 PM
tech's Avatar
went to track on sat. 2001 supercrew 5.4l 3.55 gears. 5140LBS with driver went
15.60@86.16 in quarter 9.90@69 in eight. Mods are bolt-on's
Old 02-01-2007, 11:41 AM
Don's Bolt's Avatar
I love the smell of burning rubber
I race the Lightning all the time, and even took the Bronco down the track one night this past summer
Old 02-01-2007, 01:56 PM
Neal's Avatar
Cool
HI!... Hey DON, what did the BRONCO run? Just curious.
Old 02-01-2007, 08:04 PM
Don's Bolt's Avatar
On a brand new motor, not really tuned right it ran a 16.1 at around 80 something mph. It had around 35 gallons of fuel, about 4 lbs of tools, and a big A$$ed Spare tire.
I now have a new transmision, got the new engine dialed in a lot better. So if I can get to the track with say only 10 gallons of gas, and running better, I bet I can run a high 15 second run
Quick Reply: Drag Racing
