Stock times before Charging!
My 502 Chevelle would break loose at 50. Now if you want something that I think is an impossibility, check out the ending of 'The Fast And The Furious". Has anyone else ever seen a car do a wheel stand WHILE smoking the tires like that?
My Truck Takes V8'S With No Problem!
THIS IS A V6 REG CAB 1998 F150. THE TIRES CHIRP ALL THE WAY TO 3RD GEAR, WICH IS ABOUT 50MPH OR SO. IT IS VERY FAST FOR ITS 256 CU IN MOTOR, THE UPGRADES ARE...
Air Intake, Cold Air Kit, Mafs, Throttle Body Spc, Turbonator, Fuel Inj And Fuel Pump, Headers, No Catalatyc Conv, Y Pipe, Dual Exh, Powertrac Positrac, 410 Gear Ratio, Aluminum Drive Shaft, New Tranny With Shift Kit, Centerforce Stage 1 Clutch=and Throwout Bearing, Light Weight Flywheel, Pulleys, Stage 3 Jet Chip, 75 Shot Of Nitrous, Shaved Heads For Better Compression, 20'' Wheel On Yokohama, 16'' Rims For Tearing Up The Street. And I Know I Missed Something, But That About Wraps It Up. Oh Yeah!!! I Just Bought A Electrik Turbo It Claims To Make 125 Cfm. I Have Not Intalled It Yet. Does Anyone Know Something About It??? If So Let Me Know, And What Other Upgrades You Recomend??? Please Ur Input Will Be Helpful When Spanking Them V8 Chevy's... GOT GO OR JUST SHOW???
Originally Posted by Josiah
I just can't fathom it unless you are dropping into gear from neutral. Are any of these automatics that you are speaking of?
Lightings ARE automatics.
Why is it so hard to believe? MY Mustang will smoke'em at 45-50 in third, no down shifting needed, just pop your foot off, then mash'er down. My Lightning, 35 and under, I can't get passed 2/3 throttle or they will breake loose. And my SVT Focus will light'em up at 50 if I drop it down to second. (I can take 2nd to 67mph at 7200rpms, oh, and it has 299 hp to the wheels thanks to about 10 grand over the last 3 years.)
Oh, and you go on a head and do a neutral drop 45 or 50, and hope you don't start spitting gears all over the highway or drop a drive shaft.
but I was being sarcastic. The reason I can't fathom it probably has to do with the fact that the fastest thing I've driven in was an '03 Mustang. I need to test drive something besides trucks.
Originally Posted by STOMPTHECHEVY
IT IS TRUE THAT THEY CAN SPIN AT ABOUT 50-60 THAT'S WHEN I HIT 3RD GEAR . I DO THAT IN MY TRUCK, I HAVE LOTS OF UPGRADES IN IT. 4.2 L ENGINE. COMPLETE AIR MANAGEMENT. GEARS, PULLEYS, REAR END. TRANNY'S SHIFT KIT. DRIVESHAFT 75SHOT OF NITROUS, CHIPS ALL THAT GOOD STUFF. IF YOU'D LIKE TO KNOW IN DETAIL, LET ME KNOW.
I'd like to know.
MY mods are...
Air Intake, Cold Air Kit, M.a.f.s, Throttle Body Spc, Turbonator, Fuel Inj And Fuel Pump, Headers, No Catalatyc Conv, Y Pipe, Dual Exh, Powertrac Positrac unit, 410 Gear Ratio,electric turbo, Aluminum Drive Shaft, New Tranny With hurst stick Shift Kit, Centerforce Stage 1 Clutch=and Throwout Bearing, Light Weight Flywheel, Pulleys, Stage III Jet Chip, 75 Shot Of NitrouS, Shaved Heads For Better Compression, 20'' Wheels On Yokohama, 16'' Rims For Tearing Up The Street and track, LImo tint, sick sound system, Xtang bed cover, hood scoops, tail gate wing. shaved off F150 emblems on side. etc etc
ross lewis
Yah, I know this is a car and not a truck but my buddy has a 92 camoro ss and he can break them loose at 95. He did it one day getting on I-95 and we got side ways at 90 some odd miles per hour and i had to check my pants afterwards lol. So yah i beleive every bit of it.
ROSS
ROSS
ROSS
ROSS
Wanna hear crazy wheelspin? Try 390lb-ft of torque in a 2400lb FWD car with a 4:18:1 gear ratio. I can get on it in 5th on a cold day and spin the tires past 100mph, from a roll. I one time gassed it until the speedometer read 130mph, let off and it dropped right down to 100mph. Apparently, the tires were doing 130, the car was doing 100. Yikes.
1st gear isn't too bad because of lag, 2nd is constant feathering of the throttle, 3rd, 4th and 5th require a little feathering, but once it hooks up it's fine.
I've never had the ***** to run it at its current power with slicks. The local track was (since been bulldozed, SoCal sucks for cars) pretty bumpy and 24.5" tall balloons with only 13psi in them can be scary when they're on the steering wheels at 140+mph. Maybe next time at Pomona's Import Battle...
See my sig for my best time. That was driving it to/from the track with only a minor tire pressure adjustment (25psi hot, any less and it's scary on the big end). The car will probably do lower 11s/upper 10s with a good launch but I didn't really build it for drag racing. ~130mph traps do raise some eyebrows when they see it's basically a near stock looking sentra...
Best part is seeing hundreds of feet of rubber with 4 breaks in it...
My GNs can break the tires loose at 55mph on 255-50-16 street tires.I am running 25psi of boost with alcohol injection.It can be a handful when the car wants to get sideways at 55mph.
My 6 cyl GNs can do it no problem but I'm having trouble believing a full size truck with a n/a V6 can do it.
