Showing pictures in my signature
Why is it that my picture in my signature will only show if I check the box when creating each post rather than showing it for every post automatically.
I have the box in edit options checked to show signatures, so I'm not sure what is going on?
The first post I didn't have it checked, this one I checked the box down under additional options after creating this post.
Why if you have the option checked in edit options under user cp does it not work?
Unless you do a quick reply at the bottom of each thread, you have to check the box in additional options for each post.
By default it is turned off when replying or starting a post. If you want it to show up you need to check the box for each post.
If you use Quick Reply it is checked on by default. Go figure.
