Gallery?
Just figured out how to do this. It is pretty simple. All you have to do is go to user cp. Then under edit profile at the bottom you should see gallery number. Look at your gallery and put the number in there. Thats it. save and BAM!!! you have a camera next to your info.
Originally Posted by Cuisi
I've already done that part, what I don't know how to do is make the little camera appear on the right next to my vehicle info.
It is HERE
It is HERE
The LINK that you posted contains the key....
Mouseover that link that you posted... you'll see the URL for the link show up down in the bottom left corner (IE7). See the last four digits? That's your gallery ID.
Now that you have that, it's as simple as jumping in to your USERCP (link atop the page here in a BLACK bar -- it's the first one on the left hand side).
Once you're in the USERCP screen, you'll see a 'CONTROL PANEL', click on EDIT OPTIONS.
Once the EDIT OPTIONS screen appears, you'll see the GALLERY NUMBER field all the way down at the bottom above the SAVE CHANGES button.
Tack in that code that we mentioned earlier...9726... click SAVE CHANGES, and you're GOLDEN.
That help?
=RP=
Originally Posted by ktmrdr85
I did exactly this and it's not working.
I just did it again amd the camera is not working.
CLICK USERCP.... CLICK EDIT PROFILE.... ENTER 9816 in the GALLERY NUMBER text field... CLICK SAVE CHANGES....
It works. Trust me.
