ford steel braded fuel lines
happy thanksgiving the questions never stop even on the holoday i have a problem the steel braded fuel line on top of the tank is kinked almost shut i will have to take the line off the top of the tank to twist it around but it wont be today but my question is will that line go back to its orig. shape after i unkink it cause my fuel pressur koer is 82psi!!! just wondering if i should get a new line or try to salvage the one i have thanks for the holoday info.
It has a weak spot now so it will be real easy to kink there again. Your best bet would be to try to zip tie the line to something to try an give it some support and keep it straight. Or maybe put a piece of rubber hose around it to keep it from kinking there?
-Jon
-Jon
