Winsheild Fluid System?
Ok, so my the cable that goes from my nozzles to my fluid container on my 95' 5.8L came off today and all of the fluid leaked out. I put it back into the container and only one nozzle works now. (the drivers side)
My questions are these:
IS there two cables, or are they connected as a parallel?
Is it something else making the passenger side not work?
Thanks,
Pete
Thanks,
Pete
I assume that when you say "cable" you are meaning hose. It is one hose all the way up to the cowl. Then it splits into two. My guess is that your passenger side nozzle is plugged. Try cleaning it out with a needle or similar object and see if that fixes your problem. Keep us posted
