Help
Help
Ok, I'm lookin in summit, at the Fipk Kit, from K&N. Ford: 1988-93 F-Series with 5.0L,4.9/5.8/7.4 $211.95 And then 1994-95 F series and bronco with mass air $133.95 which is for me? i'm confused
Do you know if you have mass air or speed density?
Mass air has one tube going into the airfilter housing, while the speed density version has dual tubes. This will help you out a lot. If you already know, then don't listen to the years, because I'm almost 100% sure they are set up the same way. Just get the version you need. You can always look up the k&n part # and then try to match it to the one you are trying to buy.
beastie:
I'm confused, you have MAF? Looks like a MA meter in the tubing, but you have the double TB. Did the MAF come with a double TB and that Y, or did you customize that? Anybody got any pics of a factory MAF setup on a 302/351? What year did they start on the 302/351 then, 94?
