Clutch Update
Old Oct 3, 2002 | 07:49 PM
spaceman12321's Avatar
I know I'm not the profesional but could your slave gone bad?
Been there, done that. Sure makes bleeding a B...... considering you cant bleed a bad hydrolic system. Really it shouldn't be a big deal if everything is right (at least mine wasnt after I replaced the faulty master cylinder).
Good luck.
Old Oct 4, 2002 | 09:22 PM
black8's Avatar
clutch bleed
chris check to make sure your clutch peddle arm is coming all the way up they have been known to slip at the mount bolt and not return makeing bleeding a real hassel, good luck black8
Old Oct 6, 2002 | 05:18 AM
PKRWUD's Avatar
I haven't touched it in a few days. It drives, just not well. I still only have a half in of pedal. The slave is fine, I'm just not getting all the air out. I'll either go at it again tomorrow or Monday.
Take care,
~Chris
