ATTN PKRWUD re: roller cam conversion
Old Sep 26, 2002 | 12:59 PM
Donate54's Avatar
Originally posted by JerryK
Those are the lifter link bars or "dogbones".. get it? The Spider is a stamped piece of steel w/ 8 "arms", 4 to each side. Each "arm" rests on top of a link bar (dog bone) which in turn "holds" the hydraulic roller lifters and prevents them from coming up out of the lifter bore. Hope that helps. There is only 1 spider necessary and it is about 12" long by 10" wide I'm guessing when you measure "arm to arm" and top to bottom.
Jerry
gotcha! now since my 89's block is supposed to be a roller block, i shouldnt need any machinework to install these things, correct? or will i need any work done to the block? im sorry for all the questions, i really appreciate the help!
Old Sep 26, 2002 | 01:24 PM
JerryK's Avatar
No machine work necessary, the holes are already threaded. You will need to find the right size and length screws to hold it in.. thats it.
