It's alive!
Old Aug 22, 2002 | 10:22 AM
Donate54's Avatar
Originally posted by bjoern
The mounting holes in the Lightning TB had to be widened to 9mm (no biggie at all), they match just fine in all other respects. The only real problem is to mount the idle air control valve (IAC). With the L being a charged engine, the bypass air goes into the manifold, rather than just past the throttle bores, so the L TB doesn't have mounts for an IAC. What I did was having a machine shop make me a throttle body spacer (I think 2" thick) out of aluminum (the blueprints are on the page). I mounted the IAC on the spacer and used a U shaped piece of coolant hose from AutoZone or Napa with some plumbing fittings to route air from the rubber L intake elbow to the spacer. The spacer has two holes for the bypass air: one that is right between the two intake bores and is big enough to hit both bores with an opening, so the bypassed air gets evenly into the manifold. The other hole is basically L shaped and goes anywhere you can easily mount the plumbing nipple for the hose from the elbow - that's where the air comes in. Both holes are connected by the IAC.
Was that understandable? I'll try to take some close-up pictures to go with the blue-prints on the site.
yes i understand how you did it. only reason i ask was that i was playing arond with the idea of switching to mass air and i like that idea of yours of the lightning TB, but i also saw in your site that the machine shop charged you 350 for the spacer . anyways, thanks for the idea, and GREAT job with the truck!
Old Aug 22, 2002 | 11:32 AM
bjoern's Avatar
That was totally outrageous! I'm sure another shop would make you that a lot cheaper. You could even get Micarta (the same stuff used for the phenolic spacers) and do it yourself. All you need is a drill-press (e.g. this one), a few bits and a tap set. I was going to make it myself, but I ran out of time so I thought the 200-250 he quoted me initially was ok. Had I known he'd charge me $350 I had done it myself.
Old Aug 22, 2002 | 04:33 PM
beastie's Avatar
I work at a restaurant, and the bar tenders boy friend owns a machine shop here. And I was talking to him and hes like "thats all you need? Ill get some scrap aluminum laying around the shop and do that for ya." I'm like how much, i told him about your $350 he was like that is outrageous, hes like i'll do it for free. I said thanks
Old Aug 22, 2002 | 04:37 PM
Donate54's Avatar
DAMN i wish i had friends like that!
Old Aug 22, 2002 | 06:24 PM
beastie's Avatar
I got conenctions LOL
