'78 F-150 4x4
Old Aug 12, 2002 | 12:17 AM
Fordman302's Avatar
Question '78 F-150 4x4
What are the biggest tires you can run on one of these stock? Also what would be good backspacing for a new set of wheels for this. I'd kinda like to run 33x12.50x15's on it.
Eventually I would like to lift it up 4" an run 35's.
What do you guys think?
Old Aug 12, 2002 | 03:07 AM
SPROCKET_X's Avatar
I'm pretty sure the biggest you can run with the stock 4x4 height is 33in', I'm pretty sure the widest you can go w/out rubbing would be 10.5. I think stock the wheels have a 4in backspacing and if you wanna run 12.5 on a stock height w/out any rubbing you'd probly wanna run with almost a 3in backspacing...keep in mind the less back space the more wear your bearings will receive.
