hard to start
Old Jul 21, 2002 | 02:15 PM
CHADSIX's Avatar
Angry hard to start
you guys read about my leaking fuel tank well my local radiator shop had one on the shelf for a $100.00 wich was very good price but my question is ever since i replaced my tank it is hard to start when it is cold it will crank and crank and then it will stumble into a start i hooked everything up correctly does anyone have any ideas what would cause this
Old Jul 21, 2002 | 05:58 PM
SPROCKET_X's Avatar
sounds like a bad fuel pump.
Old Jul 21, 2002 | 07:03 PM
CHADSIX's Avatar
my fuel pump was fine untill i swaped tanks and it is only 8 months old
Old Jul 21, 2002 | 09:43 PM
Ford4ever's Avatar
Sounds like when you swapped the tank you may have somehow sucked up some crap into the fuel system, try changing the fuel filter.
Hows the cranking speed? If it's cranking slow the starter may be going. If it's cranking normal but just won't start i'd look at the fuel system.
-Jon
Old Jul 22, 2002 | 11:07 AM
PKRWUD's Avatar
It definately sounds like a fuel pressure problem. You need to check your fuel pressure KOEO. It should reach 30 psi the first time you turn the key on. Until you solve the problem, you can prime the fuel system by turning the key on (do not try to start the engine) for two seconds, then turn the key off for two seconds, then on for two seconds, then off for two seconds, etc. Do this 3 or 4 times, then try to start it. It should start right up.
Take care,
~Chris
Old Jul 22, 2002 | 09:09 PM
CHADSIX's Avatar
yea someone else told me to replace the filter what i dont understand is how does anything get past the strainer in the tank enough to block the main filter how is that
Old Jul 22, 2002 | 10:03 PM
Ford4ever's Avatar
The strainer in the tank just keeps out the big crap, where as the filter traps particles down to 50 microns or so in size. IF the strainer could do that you wouldn't need a filter.
-Jon
Old Aug 2, 2002 | 03:35 AM
spaceman12321's Avatar
KOEO pressure is 30-45psi for 5.0/5.8 and 45-60 for 4.9 Check out recent post for fuel specs at https://www.f150online.com/forums/sh...threadid=84781
