Need help!!!
Old Jun 24, 2002 | 11:01 AM
Rainman's Avatar
Question Need help!!!
Okay! I've got this '93 extended cab short box with only 50,000 miles, factory Ford headers(off Mustang 302), K&N filter and a couple of other items done to my truck. Problem I have is my cruse doesn't work what can it be. Other item of confusion is nobody can tell me if I can pull a 1600lb tent trailer in overdrive. and if I can use my cruse (when I get it working)?
Old Jun 24, 2002 | 12:19 PM
PKRWUD's Avatar
Need alot more information. Engine/tranny/rear axle and a description of what is wrong with the cruise control. Did it ever work? when did it start to fail? What happened? has it gotten worse? etc., etc. The more info you give, the better the advice you will receive. If you don't know your specific rear gears, copy down the code underneath AXLE on the bottom of the VC Label on the inner drivers side door jamb, and post it here with your other info.
Take care,
-Chris
