fuel pump toast?
Old Jun 3, 2002 | 06:09 PM
BlueOval300's Avatar
fuel pump toast?
My truck has been having trouble running off the back fuel tank. I first noticed a problem when the motor would run rough when revving it passed 3,000 RPM. This was a while back. Since then, I would try running the back tank every once in a while. Sometimes it would run (but still cut out at high RPM), sometimes it just wouldn't run, period. Runs like a top on the front tank.
I'm assuming the pump on the back tank is toasted, but I'm not sure if there's anything else I should consider before dropping the cash for a new one. Any ideas?
Thanks!
Old Jun 3, 2002 | 07:24 PM
inski21's Avatar
Sounds toast alright, since its tank specific. An 88 rear tank that still holds gas...amazing. My truck had a recall on some kind of cross over valve re: the dual tanks. I haven't taken it in yet so I'm not sure of the details. Check here to see if yours has a similar recall www.nhtsa.dot.gov/cars/
Old Jun 3, 2002 | 07:29 PM
Yup....the tank still does a fine job of holding fuel.
Actually, you could count the number of problems this truck has had on one hand, and still have fingers left over.
Old Jun 3, 2002 | 07:34 PM
inski21's Avatar
Good deal!
Old Jun 3, 2002 | 10:01 PM
Ford4Fun's Avatar
...mine still holds fuel also. The recall prevents your truck from transfering fuel from one tank to the other, I don't know exactly why it does it but ford doesn't like the idea. My pump did the same thing for a while, then I replaced it and all fine.
