Ummmmm
Old May 18, 2002 | 04:11 PM
Motorcraft's Avatar
Ummmmm
OK I bought a K&N filter today not FIPK and as i was removing the old filter i noticed for first time a small filter twards the firewall of the truck this filter seems to go with a vac line and it was really nasty. I took it out and it fell apart do i need this little filter BTW its a Speed Density air box.
Old May 18, 2002 | 04:15 PM
LLoverCrazyJay's Avatar
i have it too, mine was nasty also, i'm wondering the same, and where to get it.
Old May 18, 2002 | 04:40 PM
FORD302GUY's Avatar
It is commonly called a breather filter. It filters the air that comes out of the crankcase. It dosent HAVE to be there,but if it isnt your air filter will get dirtier a little faster.
Old May 18, 2002 | 04:42 PM
Donate54's Avatar
you can get it at almost any auto parts store. just tell them you need a breather filter for your truck.
Old May 18, 2002 | 04:48 PM
Motorcraft's Avatar
Thanks for info. Why does it filer air coming out seems a small waste but what ever. Could i maybe cut a hole in the box and fab a little port for that vac line so my filter does not get dirty faster?
Old May 18, 2002 | 05:59 PM
I've got an edelbrock breather cap for valve covers, if i put that on where the rubber hose comes out from start, would it work, it's got a little filter inside...
Old May 18, 2002 | 06:43 PM
Macgyver's Avatar
it doesnt filter the air coming "out" in sucks air in to the crankcase the "out" is the pcv valve that takes the blow by gases from the crankcase and burns them in the motor . since i removed all the bottom of my air box i had to relocate . so i got a APC intimadator filter and stuck in the hose @ the filler cap . it tends to get a bit messy tho and i am thinking bout remotely locating it .
Old May 18, 2002 | 06:56 PM
Motorcraft's Avatar
Ok so this means i should go buy a new filter for it..... I wish K&N made one............ Well Guess i will be at auto zone before i go to work on sunday..:o
Old May 18, 2002 | 08:56 PM
Macgyver's Avatar
the one i have is very simular to a K&N.
Old May 19, 2002 | 08:49 AM
inski21's Avatar
Mine is very similar to Mac's. Mine is an APC, I stuck mine on at the end of the long tube and it resides with the 2 cone filters.
Old May 19, 2002 | 08:51 AM
inski21's Avatar
Sorry, Mac's is an APC too. (i'm a dummass)
