thermostat help...
Old Apr 13, 2002 | 03:26 PM
Donate54's Avatar
thermostat help...
ok guys, im replacing my thermostat on my engine and i had a little trouble with the housing bolts (ive fixed the problem, but i dont want to have to remove the housing again). heres my question, half the people ive talked to have told me to run the engine with no thermostat, while others have told me to stick to a 180 thermostat. what should i do? im leaning towards putting in a new 180 t-stat, but would it be better to run it without one? wouldnt this cause the coolant to run too fast thru the radiator and not have enough time to cool off? my dad swears that he has removed his t-stat out of every trck he's owned with no problems whatsoever. opinions? thanks!
Old Apr 13, 2002 | 03:38 PM
Macgyver's Avatar
well the problems with that is 1.) your temp constantly rises eventually boiling over on a hot day ,(especially in traffic ). 2.) your motor doesn't maintain a good temp (to low) to run properly . 3.) in the winter your heater sucks ....lol
Old Apr 13, 2002 | 03:48 PM
Donate54's Avatar
so you suggest i stick with the t-stat? im notworried about the heater in winter, our winters here are like 70 degrees . i think im just gonna go ahead and stick with the t-stat. any other opinions?
Old Apr 13, 2002 | 07:04 PM
FORD302GUY's Avatar
Not only would I put a thermostat back in I would use a 192 degree. No thermostat or one thet is the incorrect temperature will cause your trucks computor to think that the engine isnt warmed up yet. 192 degrees is what they are equipped with from the factory.
Old Apr 13, 2002 | 09:48 PM
dbarbee's Avatar
Don't forget that when you decrease your coolant temperatue, you also decrease your engine oil and metal temperatures. This results in INCREASED wear in bearings and cylinders.
Old Apr 14, 2002 | 02:57 AM
signmaster's Avatar
I agree with the above. Use a stat and preferably the stock 190 or whatever it is.
For the half that say don't use one urge them to see a doctor. With some lubrication and effort they can be cured of their cranial rectumitis!
Old Apr 14, 2002 | 05:35 AM
PKRWUD's Avatar
Unless you have a chip that says otherwise, use a 192 degree t-stat, preferably bought at your local Ford dealership. Avoid Stant t-stats at all costs.
Take care,
-Chris
