tranny fluid question...
Old Mar 27, 2002 | 12:07 PM
Donate54's Avatar
those of you with 5 speeds, do you use gear oil or ATF in your manual trannys? i think i asked about a year ago, and the majority told me atf because that is what is recommended. every mechanic i talk to, though, tells me to stick to gear oil because atf is too think and it wont lubricate "hard to reach places" as good as gear oil can. when i bought my truck he tranny was already damaged due to the fact that it was low on fluid (atf), and after i rebuilt it, my mechanic has told me to use gear oil ever since. ive had absolutely no problems, and i was curious to see if any of you guys are using gear oil also. i just want to make sure that im not hurting the tranny in any way (since the recommended is atf)thanks...
Old Mar 27, 2002 | 01:22 PM
PKRWUD's Avatar
I use ATF.
Take care,
-Chris
Old Mar 27, 2002 | 05:59 PM
bjoern's Avatar
On my mechanics recommendation I put in gear oil once. After that it was hard to shift and mileage went down 2 mpg. I drained the tranny and put Mobil 1 synthetic ATF. Now it shifts fine and I get the 15-16mpg I'm used to.
Old Mar 27, 2002 | 07:33 PM
Macgyver's Avatar
ATF in a manual trans? WTF are ya thinking?......lol...90wt is all i've ever used in a manual trans . WTH ATF in the rear end then too?.........lol
Old Mar 27, 2002 | 08:36 PM
Donate54's Avatar
tahts exactly what my mechanic buddy said. the gear oil isnt giving me any trouble, and my tranny shifts great so i think im just gonna leave it alone for now.
Old Mar 27, 2002 | 08:40 PM
SPROCKET_X's Avatar
since we're on the subject of the manual tranny...how full should I fill it with fluid....till it starts coming out of where I fill it on the side?
Old Mar 27, 2002 | 08:53 PM
Ford4Fun's Avatar
yeah up to the fill hole. FWIW I use merc 5 in my tranny, it has never had problems and over 200k miles.
Old Mar 27, 2002 | 09:10 PM
SPROCKET_X's Avatar
ok good...wasn't sure cuz thats what I did 20k ago....BTW I just hit 100k in my 96 300ci and still going strong!
Old Mar 27, 2002 | 09:34 PM
inski21's Avatar
The service manuals say ATF. My mustang -5spd, had ATF. All saturn manuals use atf. ATF is thinner than gear oil, it also has better cooling properties, and clings better.
I think either will work fine. Some synchronizers have automatic type clutch material on them
Glad yours is fixed Donate
Old Mar 31, 2002 | 03:55 PM
Ford4ever's Avatar
Because of the material on the synchros you can't really pick or choose. Use whatever the owners manual says.
-Jon
