Dual fuel tanks
Old Mar 21, 2002 | 07:47 PM
SlyBytrksR4grlS's Avatar
Question Dual fuel tanks
I have a 1995 Ford F150 XL with dual fuel tanks and sometimes it won't let me fuel up. I know both tanks are empty but it does the automatic shut off as if it was full. Why does it do this?
Old Mar 21, 2002 | 07:51 PM
Macgyver's Avatar
the check valve in the tank .
Old Mar 21, 2002 | 07:57 PM
How do i check the valve?
Old Mar 21, 2002 | 10:29 PM
Macgyver's Avatar
not check the valve . there is "check valves" in the neck of the fuel tank . it is a spring loaded valve . normal pressure from the fuel entering lets fuel in but not out . it maybe faulty . we had ford chassi motor homes that that fual fillers weren't high enough about the tank not allowing enough pressure to open the valve to let more than 50 cents of fuel in at a time . would take forever to fill a 60 gallon tank !!!
Old Mar 25, 2002 | 11:10 PM
Smile
OH OK. I read it wrong, that is what it does, it only fill like 50 cents at a time, only one of the tanks does it. I know what you mean about taking forever, that is no fun, thanks for replying
Old Mar 25, 2002 | 11:12 PM
Macgyver's Avatar
check the routing of the hose . try to make a low spot in it along it's route somehow . and see if that helps ??
could also possibly be a blocked/kinked vent line?
Old Mar 28, 2002 | 01:49 AM
Fastguy's Avatar
My front tank has started doing this too, and once in a while I get a gas smell. Is it common for the vent lines to get clogged?
Old Mar 28, 2002 | 07:53 AM
Macgyver's Avatar
well depends on your local . in the south mud daubbers like to build nest in there ...lol.....
Old Mar 29, 2002 | 10:44 PM
Ford4Fun's Avatar
mine does that on occasion, try pulling the fuel filler nozzle out about 1/4 - 1/2 inch, usually helps mine.
