Tornado Engine Performance Maximizer?
Old Feb 24, 2002 | 11:55 PM
pandt_hamman's Avatar
Question Tornado Engine Performance Maximizer?
This engine performance maximizer made by Tornado installs inside air intake hose between air intake and air filter box on electronically fuel injected vehicles. It is suppose to create a swirling motion, constantly forcing air around corners and bends and through the intakes. Is this for real? Does this thing work? Will it improve gas mileage and horsepower? It is for years 75-00 fullsize pickups.
Old Feb 25, 2002 | 12:02 AM
Macgyver's Avatar
hi again pandt .
from what your saying this is simular to a poweraide that has alot of controversy about it's actual performance gains here on the boards . from what i understand from the majority of people that have tried it is it isnt worth the bang for the buck. again that is a spacer that goes between the throttle body and the intake so it does restrict the airflow . if this is something that goes inside the intake tubes from the air filter it would restrict the airflow and thats not what you want . an FIPK or modified airbox is going to give you a better bang for the buck. FIPK's are going to run $150 to $200 . i did my airbox mod for $50 (K & N drop in filter and crankcase filter ) then once you get good airflow into the motor check into exhaust .
Old Feb 25, 2002 | 12:13 AM
RAY, how ya doin'? My name is Tim. I also have already put in a K&N air filter. Will a K&N crankcase oil filter help also? What do you mean by checking into exhaust? Do you mean to see if my exhaust is obstructed?
Old Feb 25, 2002 | 12:37 AM
fivept0's Avatar
You should look at Ray's gallery to see the air box mod. I just did this and noticed big increases in hp.
about the exhaust.....He means you should consider installing aftermarket exhaust...(catback, y pipe, headers)
Old Feb 25, 2002 | 02:33 AM
signmaster's Avatar
Mod the air box and forget the Tornado. The intake on these trucks is easy to mod, and they respond well. I did mine slightly different than Ray's. My friend got a FIPK. Seat of the pants mine worked just as good.
For what they want for a Tornado you could put the money towards pulleys or something else that will actually help.
