Codes Gone MPG has improved
Old Feb 24, 2002 | 02:43 PM
Macgyver's Avatar
i did the hand pump thingy on the egr again yesterday . it cleared the code 32 right away without resetting the ecm . i havent drove all that much since then but i checked it again today and the code is still gone and it seems as if i am back to close to 15 mpg .i'm going to top off the tank a bit later and i will know for sure what it is then....
Old Feb 24, 2002 | 03:21 PM
inski21's Avatar
isn't your EGR new? Are you getting vacuum at the EGR? Mine stuck once, then I smacked it w/ a ratchet handle, freed it up for 25k miles now. Some times Saturn egrs can be "fixed" the same way. Sometimes the diaphrams cant hold much vacuum because they develope small leaks. Good luck.
Old Feb 24, 2002 | 03:44 PM
Macgyver's Avatar
well chris and i both believe it is sticking . yes it is new . but that dont mean it works right ....lol......sounds like a fix i use for sticking gas valves . a good smack free's them up ...lol....on the other hand tho if it is sticking and i need to take it back i dont want a dent in it where i "Smacked" it ..lol..
Old Feb 24, 2002 | 03:51 PM
inski21's Avatar
Lol, ya don't smack it too hard. Take yours off and push up the pintle. If it doesn't come back down, take it back. I tried cleaning one once w/ brake clean and it stuck worse. Dam emissions. We could get these things running mint if we didn't have to work with this emissions crap all the time.
Old Feb 24, 2002 | 03:58 PM
Macgyver's Avatar
well i have been using a hand vacuum pump on it and it seems to move ok and then the code clears . but last time the code returned . it hasnt yet this time but if it does i am taking it off and returning it .
Old Feb 24, 2002 | 07:33 PM
Macgyver's Avatar
well i guess i was wrong about the MPG .... lol seems to be about the same 13.56 city/hiway
Old Feb 25, 2002 | 11:14 PM
curt73@aol.com's Avatar
Ray
well i would be happy with that mpg, i am getting like 6 mpg, have the same issues as everyone else with the idle. I haven't had time to work on it yet so I will get back to that issue. My rear bearing is shot, getting grease on my axle and my shock and every where honestly. i need to do the valve cover gaskets and change some hoses. to top it all off i need a complete exhaust. i also have to pass inspection in less then a week. lol
want to talk about problems.
curt
Old Feb 25, 2002 | 11:31 PM
Macgyver's Avatar
lol curt
