1990 F150 Questions
Old Jan 14, 2002 | 02:31 AM
westtexastiger's Avatar
1990 F150 Questions
I have several questions that I would love to get some help on. I have never been able to find information about the power output of my motor, a 1990 302 V8 EFI. If anyone could tell me or tell me where to find the horse power and torque specs, I would greatly appreciate it.
Old Jan 14, 2002 | 03:42 AM
TF's Avatar
TF
You asked for it, you got it:
1990 F-150 302 power specs:
Peak horsepower: 185 @ 3800 RPM's
Peak torque: 270 lb/ft @ 2400 RPM's
My truck:
1990 F-150 4x4 XLT Lariat
Short bed, Regular cab, solid charcoal gray
Rebuilt 302 V8, AOD transmission
4.10 gear ratio with limited slip diff.
Crane Cams Compucam
K&N FIPK
Gibson shorty headers
High flow cat. conv. with 3" pipe
Flowmaster "40 series" muffler with dual turndowns
Tough Country 4" suspension lift
Extended radius arms
Dunlop 35x12.50" mud terrain tires
Ultra aluminum 15x10" rims
Alpine CD7840 cd player
Alpine amp
Infiniti 6.5" speakers with seperate tweeters
MTX truck box subs
Delta diamond plated toolbox
diamond plated bed rail caps
Ford trailer hitch receiver cover
Mods. to come:
Superchip
MSD ignition system
Grill guard
shift kit
Superswamper 33x15.50" TSL radials
much later:
Edelbrock aluminum cylinder heads
Edelbrock intake manifold, throttle body, headers, water pump
possibly a 351 engine swap
maybe a 6" suspension lift or a 3" body lift
Old Jan 14, 2002 | 08:16 AM
Donate54's Avatar
TF,
kinda off topic, but how do you like that crane compucam?
Old Jan 14, 2002 | 08:06 PM
TF's Avatar
TF
Donate54:
Well, to be honest, I would only recommend getting the cam if you will be tearing apart the engine any ways. It's a lot of work/money to replace a cam and it doesn't make a big enough difference to warrant a straight cam swap. However, I had it put in when I replaced my engine a year and a half ago so there was really no extra labor required, and at about $150, it wasn't too expensive. To be honest, though I really can't say how much of a difference just the cam makes since I got a new engine at the same time, and as we all know, no two engines are alike. But my best guess is that it is similar to most of the bolt on mods-- it's not going to change the personality of the engine, it'll just give it a little extra push. Hope this helps.
