EEC Codes and High Idle
Old Oct 12, 2001 | 12:21 AM
ford-tough1's Avatar
I have a 93 F150
For the continuous codes I get
179 Rich HO2 sensor
327 EGR feed back signal low
334 EVP sensor high
634 Neutral/park position switch
For the running test.
All I get is a code 632-Transmission control switch needs to be cycled. I pressed the brake after the ID code and I still get the code.
The reason I am checking codes is for a high idle.
I have sprayed carb cleaner and water around all vacuum lines and gaskets with no change in the idle.
I checked the TPS and EVP sensor, and they both checked out.
Now for the questions.
1. How do I get around the code 632 to do the running test?
2. Any other suggestions about the high idle.
This weekend I will swap out the egr valve with a known good one, clear the codes and check them again, and possibly swap out the Ho2 sensor.
3. What else would cause these codes?
4. Is there a way to adjust the N/P sensor and what happens if it completly goes out?
Old Oct 12, 2001 | 01:10 AM
Donate54's Avatar
maybe your O2 sensor has gone bad? as far as the idle, do you have any vaccum leaks? sorry i couldnt be of much help.
