94 f150 issues?
Old Oct 18, 2020 | 03:30 PM
Downeaster's Avatar
94 f150 issues?
I'm looking to buy my first f150. I found a 94 5.0 2wd with 130k miles. Any big things I should look for? Oil is leaking from the front of engine but that's about all I noticed.
Old Oct 18, 2020 | 06:45 PM
Roadie's Avatar
If it has been taken care of, it should have lots of pleasure packed miles left in it. Might be worth the money to get a mechanic to inspect it.
Old Oct 22, 2020 | 09:14 PM
Strunkie's Avatar
I just got a 93 F150 Flareside with 5.8 (190k miles) from a field which it had sit for almost 2 years. I had an intermittent starting issue which is posted in here. However, I have the same small oil leak on the front of the motor and I think its the distributer oil seal. Not positive but cant find any oil from either valve cover? I have ripped the upper manifold off and found all kinds of little things like fuel injector pig tails of which 3 of 8 were chaffed and had bare wires, so I replaced the pig tails. I also replaced the injectors as I also had a a hot start which the pedal on the floor cranked right up.
So, I think I had fuel injectors leaking fuel into the cylinder when hot which caused my slow start. Most embarrassing find was I went to change the plugs and I found #5,#6, #7 plugs were so lose I spun them out by hand and I had one more on the other side which I turned the tip of the plug and spun it right out. So go over everything simple like a basic tune up. I had a bad ICM which contributed to my starting issues. I found the plug below the plug wire on the coil had a broken lock tab. Rewired a new plug that locks on the coil. I had a code in the PCM for bad O2 sensor and I changed that out which was the original O2 sensor.
Even after all of that, I fell the engine is still solid and the E4OD tranny shifts super smooth and pulls hard. I think I got a decent truck for $2500. Will need lots of TLC to get it running as good as possible but I do all my own work. If you don't do your own work, you should get a mechanic to look it over and at least interrogate the OBD system for codes. I agree, if the truck has been maintained, it will do you good once its gone over by a solid mechanic.
