Tire size question
Old Feb 24, 2019 | 12:30 PM
RaginCajun28's Avatar
Tire size question
I have a 1995 f150, 2wd, single cab,4.9 straight six.
I have the opportunity to purchase a set of wheels and tires for really cheap check on rim size they will fit the truck 17x8 +10 offset 5x5.5 bolt pattern. Tire size seems pretty big though at 265x65R17 measures 30.6 diameter x 10.4 inches wide my question is will they fit without rubbing(no lift)
Old Feb 24, 2019 | 01:54 PM
I don't know, but the only 17" wheel and tire packages that Tire Rack sells for your truck are 17x8 with 0, +10, or +20mm offset or 17x8.5 with -06mm offset and 255x55R17. Those are just over 28" diameter.
Old Feb 24, 2019 | 02:14 PM
I found it
While I was doing research I ran across a green 95 f150 stock height running 265/65r17 no rubbing no spacers on custom offsets but his was 17x9 -12 offset probably looks better than a +10 would anyway not tucked so bad I found a set of kmc wheels I like with same measurement just have to save a little more but thank y'all for y'all help
