1992 f150 cruise and horn inop
cruise and horn inop on extremely clean low mileage 1992 f150 with 302. This truck is pre brake pressure switch and I don’t see any other common causes. Can anyone help? It’s a reg cab and both powder windows are Inop as well. Door locks work and all fuses and relays seem fine. Thanks in advance
If you've checked all your fuses, I'd agree that it would be in the column, possibly the clockspring contacts or the plug.
I don't know how you're getting an airbag light on a 92 though; F150's didn't get airbags till 94.
The 92 clockspring setup is quite simple, spring loaded contacts rub on a circular tack of copper to make a connection. Might be worth pulling the steering wheel to have a look at that.
