96 5.0 oil pressure
Old 11-30-2013, 04:49 AM
Billdo1127's Avatar
96 5.0 oil pressure
I have a 96, 150 that I put a long block 5.0 in 3 years ago. Family issues have set me back and I am just now getting it up and running. It starts right up and sounds good but the oil pressure gauge is reading "negative" on the dash. By which I mean that when I turn the key on, the needle moves into the middle of normal range but when you start the truck, the needle moves beyond low. I have had no over heating.
I made sure to prime the oil pump before I started it a month ago, have no leaks anywhere, and have put around 20 miles on the truck with no problems. Now I did have to put a wire harness from a pick and pull on when we first started the project, but was unsure if me crossing wires would cause it to read backwards.
So I guess my question is, what would be my best course of action? is there a way to check if the oil is circulating properly without like pulling valve covers etc.?
Old 11-30-2013, 07:37 AM
nonwoven29's Avatar
There should be only one hot wire running to the transducer/oil psi sending unit. If you want to check pressure just plumb an analog guage where the transducer is.
Hope this helps
Old 11-30-2013, 09:42 AM
Billdo1127's Avatar
Sending unit is located driver side, between oil filter and front of block correct? Will give it a shot and post results. Thank you.
Old 12-11-2013, 11:12 PM
93f150302's Avatar
Just so you know the stock gauge is a dummy gauge. Basically it reads 5psi or none. If you want to know exact pressure run an electrical gauge in the cab. On a cold start with 0W30 I read about 75-80 PSI on a stock style pump. And about 25-30 when hot. 5.0 engine btw
Quick Reply: 96 5.0 oil pressure
