'89 4.9 Tachometer
'89 4.9 Tachometer
Water pump shaft broke, fan came off, serpentine belt broke.
Replaced fan clutch, water pump and belt. Started up and found that the tach no longer works. When I start, the needle goes to 2200 and stays there while running. When I shut down, the needle drops back to zero.
On the wiring diagram a dark green/yellow wire goes through a capacitor to the tach (no resistor). On the 8-cyl there is the same capacitor plus a resistor.
Where is the capacitor and what is the value?
Replaced fan clutch, water pump and belt. Started up and found that the tach no longer works. When I start, the needle goes to 2200 and stays there while running. When I shut down, the needle drops back to zero.On the wiring diagram a dark green/yellow wire goes through a capacitor to the tach (no resistor). On the 8-cyl there is the same capacitor plus a resistor.
I had an instrument cluster I had gotten off of evilbay years ago, w/ tach. (mine doesn't have it). Couldn't get the tach working even though it was supposedly plug and play. Knowing me, I took it apart, but I only remember vaguely there being boards inside. Good luck, keep us posted, Dave.
