Headlight
Old Oct 4, 2013 | 01:25 PM
metalworker's Avatar
Headlight
1993 Ford F150, 336,000 miles and runs good. Recently found passager headlight out having changed both lamps after 14 years of service. Replaced both lamps and driver's side high & low beam works correctly. Passager side low beam will only work if I turn on the high beam first and then switch to low beam.
If I have the switch in low beam, only the driver side head light comes on. If I switch to high beam, both headlights come on and then after about a minute or so I switch to low beam and then the passager side low beam will be on and stay on as long as I like.
What can be causing this?
Old Oct 6, 2013 | 09:34 PM
adrianspeeder's Avatar
A defective bulb shorted internally would be my first guess. Swap the bulbs side to side and see if it follows.
Adrianspeeder
