93 f150 brake help!
Old Sep 8, 2013 | 05:07 PM
93f150302's Avatar
Originally Posted by adrianspeeder
The clip is for anti rattling. Not a big deal to me personally.
If the caliper is still dragging, you need to clean the scale and rust off the caliper bracket track so it moves freely back and forth without much effort.
Or you have cheap *** wrong pads.
Adrianspeeder
I think the pads are too thick I used an entire bottle of brale cleaner and a scrubbed everything. So I can leave that clip out? Cause with it in the pad can't move.
Old Sep 8, 2013 | 05:19 PM
93f150302's Avatar
Adrianspeeder
Ok now I took one of the little metal? Shims off the big pad that helped with the dragging if I take the shim off the small pad I think that will fix the issue.
Old Sep 8, 2013 | 08:15 PM
93f150302's Avatar
Everything is back together and working great. Thanks for the help guys really appreciate it.
