Solid Axle swap
Old Apr 4, 2013 | 09:49 PM
1989xltHolton's Avatar
Went to the junkyard today the sterling 10.25 is 150 bucks! has 4.10s and a l/s picking it up as soon as i get paid. Now i just need to find a dana 60 for the front
Old Apr 7, 2013 | 12:42 PM
rclark12's Avatar
Short or long pinion ? But not bad either way. Didn't realize you were going d60 are you doing leaf or coils ?
Old Apr 7, 2013 | 01:04 PM
idk didnt check looked up the code it said 4.10 and l/s out of a 1991 ford f250. Um i want to have a dana 60 and idc which one i do if i find one with coils i will do coils if leafs i will do leafs.
Old Apr 7, 2013 | 01:10 PM
Also found a set of 38 tsls on 16.5 rims for 400 have roughtly 1/4 thread left picking them up soon hopefully.
Old Apr 7, 2013 | 09:02 PM
rclark12's Avatar
no such thing as a coil sprung d60 to match your 10.25 rear. Also that is a short pinion I believe they upgraded to the long ones in 92 but you could double check that. Going coil simply requires a little custom work, leaf swaps are easy but it isnt a no fab job because you need to make a crossmember for the frame horns that strengthen the area and have you spring mounts, also I would reccomend the sky manufacturing shackle flip kit from an f350. Does wonders for ride quality and you get a good amount of lift. When I was going to do a leaf d60 on mine thats what I was going to use but now Im going coil
Old Apr 9, 2013 | 01:37 PM
Yeah its short pinion its out of a 91 f250 i cant go over 4.56 gears but i dont think i will ever go bigger than 38s and with those gears i will be fine, and the junkyard i go too has a small gated place it has a 78 or 79 f350 i think im purty sure its 4x4 that should have a dana 60. if it is i will pick it up he will probably want 100-150 for it. And i seen about the cross memeber for the leaf swap seems fairly simply i feel i can do it, if not my uncle is a welder and he makes custom bumpers etc he could make it for me if i needed him too.
Old Apr 9, 2013 | 05:36 PM
rclark12's Avatar
No good my friend, you need yourself an 85.5-91 d60. The 78/79 is a 32 inch perch width, you need 36. Along with the fact the pumkin is over toward the center more with the 78/79 d60 so your drive line wont be as good. Its a good axle, but not for this application. I sold my 79 and bought a later year king pin with a couple hundred to spare though. Ignore my sig I never had time to change the 79 d60 part
Old Apr 10, 2013 | 01:54 PM
russo2's Avatar
If you can get the 79 d60 for 150 bucks as well do it.. then sell it for at least double that. An 80-96/7 d60 sells for 500+ in bad condition.
Old Apr 10, 2013 | 03:11 PM
Damn well I will look around for other junkyards the Dana 60s I find on Craig'slist are like 600-800$ which I guess is a good price for one.
Old Apr 10, 2013 | 03:47 PM
russo2's Avatar
That's normal price for just the axle, cheap with springs and trac bar etc. You can use a 77-79 f250 8 lug d44, cut the perches off and weld on some coil mounts or go leaf sprung front and move the drivers side perch.
Old Apr 10, 2013 | 07:24 PM
rclark12's Avatar
^ this is true, but for what its worth to do that your better off finding a coil sprung d44 and converting it to 8 lug. The later year king pin ford axles will usually run from 400-800. People usually ask a grand but no reason they shouldn't take 800. I paid 350 or 400 for my later year and sold my 79. I've seen the 78/79 axles sell for over 1200 plenty a times, I didnt get that though unfortunately. Sorry Im rambling, moral of story either get a later year king pin ford axle, you can use ball joint axles too if you dont mind ball joints, or you use late 70's 8 lug d44. Thats for a leaf swap. For coils either a d44 set up for coils or start looking into coil d60 swaps, little more fab required
Old Apr 10, 2013 | 07:51 PM
russo2's Avatar
I personally don't think any 44 should go for that much ever. I could of picked up an 8 lug 44HD for 200 bucks last week. It may still be there, but I don't want 8 lug.
Old Apr 10, 2013 | 09:46 PM
rclark12's Avatar
Im lost I was only talking about d60 prices above? D44 definietly shouldnt ever go for more then 2 unles its coming with stuff. By 79 in my post above I mean 79 d60, highly sought after axle just not for this project
Old Apr 11, 2013 | 11:25 AM
If I did find a 78/79 dana 44 could I convert it to 8 lug with 1991 f250 front axle parts? I just want a dana 60 because even with chrome moly axle shafts I still wont feel to comfortable running 37s or 38s on it and wheeling it.
Old Apr 11, 2013 | 12:40 PM
russo2's Avatar
No, the ttb uses A different style knuckle.
Just get a 60 if you plan to wheel 38's
