Help Won't Start Fuel Pump or relay????
I have a 1990 F150 XLT Lariat with A/T and 5.0 The front tank quit working on me a couple years ago so I have only been using the rear tank. Truck ran fine yesterday, when I went out to start this morning would not start. Truck cranks so battery, altenator and starter good. I did notice I don't hear the fuel pump prime as I normally do. I do hear the relay under the hood click, where should I start from here, could the relay be bad even though it is clicking or anyting else I could check that may not be the fuel pump. Once again this truck has the duel tanks and the front tank has not been working for years. Thanks for any help or suggestions.
Just so you know, the 1990 models no longer have the in frame pump. They started putting a high pressure pump in the tank(s) and done away with the in frame pump. 1990 was the first year for this. I just thought I would point that out.
You need first 12v on the yellow power input to the fuel pump relay, and then 12 on the dark green/yellow wire after the key is cycled. This is only a few seconds if the engine doesn't fire.
Additionally, you can manually ground the fuel pump relay causing it to trip and run the fuel pump with the light blue/orange wire on the OBD1 port making it easy to shoot for power the rest of the circuit.
Next power runs to the inertia switch under the dash near the brake master cylinder, so check for 12v there.
Now, pull the dash switch and input is red/yellow. Front tank output is the red wire, and rear tank output when selected is brown with white.
Adrianspeeder
