83 f150 charging problem
Old Jan 23, 2012 | 01:53 PM
tdbaker156's Avatar
please help. i have an 83 4x4 f150 with a 302 manual tranny. good battery brand new alternator good starter brand new voltage regulator and new sylenoid. i can jump the truck or push start it and it will start but the voltage regulater isnt registering to charge the battery. is there a wire that i need to look for or something else? i am stumped.
Old Jan 23, 2012 | 06:27 PM
dozerdog's Avatar
try the clutch safety switch, not sure where it is on your truck though.
also check your negative cables [any ground cables], for corrosion and clean them, re-attach.
Old Jan 23, 2012 | 08:32 PM
Matts ford's Avatar
have you had someone actually test the battery? if a battery gets bad enough sometimes it wont take the charge. other than that i agree with the above reply. the guys in the pre97 forum will be familiar with your system
Old Jan 24, 2012 | 01:34 PM
tdbaker156's Avatar
yes they tested the battery and ive tried a few different ones. but ok ill post there
Old Jan 24, 2012 | 03:09 PM
MITCHYKINS's Avatar
does the battery indicator lamp work when key on engine off
Old Jan 24, 2012 | 03:54 PM
tdbaker156's Avatar
i dont have a battery indicator lamp i just have the gauge.
