urgent brake master cylinder
Old Nov 9, 2011 | 12:20 PM
johny89's Avatar
master cylinder and bleeding
because of a brake pedal going to the floor (at the same time of the bearing that were broke?) pedal to the floor actually happened since i change the brake pads (and as stupid) as it is disconnected the front line.
i already changed my brake booster which had the hissing thing. i bled my brakes today (only front) do i need to do the rear at the same time? brake travel is already less then before wich is good.
but i thought it should start braking from the moment you hit the brake? is this right or not?
Old Nov 11, 2011 | 07:00 PM
The rears need to be bled BEFORE the fronts - you start bleeding at the one farthest away from the master cylinder then do them in line length order.
Old Nov 11, 2011 | 07:03 PM
johny89's Avatar
thanks ill try tomorow
Old Nov 14, 2011 | 11:49 AM
truckdude239's Avatar
brake travel should be 1/4 to 1/2 inch before engage, always start bledding like so right rear , left rear, right front, left front
Old Nov 14, 2011 | 02:37 PM
johny89's Avatar
does the engine has to be on (runing) while bleeding,
btw is there an easy way loosening rusty bleeders?
Old Nov 14, 2011 | 03:04 PM
It's a lot easier to bleed with the engine running so you have boost. Try some PB Blaster on the screws.
