headers?
Old Oct 9, 2011 | 06:02 PM
sweats91's Avatar
headers?
So I just discovered my exhaust manifolds are both cracked, not bad cracks but still. Its a 92 w/5.0 , e40d 2wd
Anybody put headers on theirs and what are the best options for under $300
Old Oct 9, 2011 | 06:56 PM
losthillbilly73's Avatar
http://www.jegs.com/i/Flowtech/387/91627/10002/-1
check them out good price and you dont have to modify ur y pipe just swap ur manifolds with these "new gaskets too of coarse"
tip if u heat the 2 bolts holdin the manifold to the y pipe they come out ALOT easyer
i never herd of this brand but they are cheaper
http://www.jegs.com/i/Pace+Setter/766/70-1322/10002/-1
Old Oct 10, 2011 | 12:57 AM
bikertrash3531's Avatar
If you retain factory exhaust losthillbilly's advice is the way to go. Not much work involved to swap them out. I have the same set up in my red 90 (5.0 E4OD 2wd) and I did duals with long tube headers, x pipe, HF cats, and Spintech muffler with 2.5" pipe. With everything I paid almost $1k including installation. I would advise against my route unless you plan to mod. if your staying stock shortys are the way to go.
Old Oct 10, 2011 | 01:16 AM
booba5185's Avatar
I wonder if its just a generic pic, but those look to have 02 bungs on both headers. If they do, they wont work.
Old Oct 10, 2011 | 01:24 AM
Most muffler shops have machine headed block of bolts if they won't be used. I had one in mine before I got an extended pigtail for my o2 sensor. which was only like two hours.
Old Oct 10, 2011 | 01:33 AM
booba5185's Avatar
Yea, they will work if you plug them. I'm wondering why they're there in the first place, If it were for a 351 I'd say EGR, even then, they'd have to be in the front of the manifolds. Must be a generic picture of some sorts.
Old Oct 10, 2011 | 09:51 AM
If I ran shortys I would like to have them in that location. The o2 would be up and away from everything else, easier to get to, and probably read better at the collector than say further downstream. Also those maybe there for mustang application. If losthillbilly did a random search for 302 headers and not headers specific to a f150, that may be why they're in that location. Further more may not run to the stock y pipe correctly. Im not sure, but it would be worth asking jegs that question.
Old Oct 10, 2011 | 11:36 AM
GTRider245's Avatar
My bet is that they are using a generic photo. No header for these trucks should come with a bung welded in.
Old Oct 10, 2011 | 05:03 PM
na they r spacific for the truck probly just a jenaric photo
