New Truck!!!
92-96 have a dual bucket seat with a fold down center console. and its already on a bench seat frame so u just pull ur bench seat and bolt this one in no cuttin or drillin prob take 10 or 15 mins to swap ill put up a pic a little later once i go outside of what they look like
exatly the xlts and customs had these seats the xls only had full bench but lkike i said these drop right in use all the same bolts.
fyi start all the bolts b4 tightening them bc if u just tighten them when u get to the last bolt it woulnt line up. but ive dun the swap from takin the bolts out to tightening them on the new seats took me 10 mins
Great...Yea I am not going to go all out. This is my DD for awhile, got to get threw the hard winters here and what not.
When you run around for awhile, what is your temp gauge at?
Mine barely gets past cold. Its in the "normal" bars, but on the far left near C. Is that bad? I ran it 40 miles at 55mph and still it stayed there...
na just means u got a 160 i normaly put a 180 degree thermostat in my trucks got a 190 n it stays aroundthe o and r in normalbut as long as it registers and aint redlining u should be alright but its easy to put a thermostat in and they only cost 5 if that pick urself up a good 180 and a new gasket. the person b4 u could have also taken it out my 86 cutlass wouldnt heat up so i pulled the housing n the guy b4 me took it out u never know
These trucks need a 190 degree thermostat, not a 180. A 180 will cause it to runrich and be stuck in a warm up loop. These trucks are warmed up at 192 degrees (Using the ECT for reference. Don't make the problem worse with a 180. Get a 190 or 192 if they have them, and don't forget to test the thermostat before you put it in (boiling water with a thermometer of some sort).
Here Are some pics guys...just found the camera!
http://i1117.photobucket.com/albums/...ewstuff025.jpg
http://i1117.photobucket.com/albums/...ewstuff024.jpg
