F150 V8 won't start
Old Aug 18, 2011 | 08:35 PM
2Desertrats's Avatar
F150 V8 won't start
45k with new battery, starter tested good, replaced solinod on fender. Turn key and just get click. Need a wiring diagram. Help
Old Aug 18, 2011 | 08:55 PM
losthillbilly73's Avatar
make sure ur battery terminals are tight. if u have aftermarket ends they suck and always screw up most times i take the plate that holds the cable and flip it upside down so it clamps tighter
if that dont work either get a haynes or chiltons
or theres a guy on here steve83 he has all types of diograms and how to.
if im not mistakin he will probly comment you soon
Old Aug 18, 2011 | 09:27 PM
AK Outlaw's Avatar
Mirror the above. Make sure you're connections are good, especially if you have the aftermarket clamps. Try cutting down your cable a little to expose some fresh wire, maybe even filing it down a bit before re clamping.
Old Aug 19, 2011 | 07:20 AM
adrianspeeder's Avatar
Relay on the fender only powers up your underhood fuse box, so that most likely isn't your problem. You need to trace the small trigger wire from the relay on the starter itself back to the key switch for power.
Handy things to also post are 5.0 vs. 5.8 and M5OD-R2 stick or E4OD auto.
Also pick up an older Haynes manual.
Adrianspeeder
Old Aug 19, 2011 | 11:34 AM
Steve83's Avatar
Remove, clean, & tighten both battery terminals, and inspect the cables carefully. Read these captions:
Then move down to the block ground & the starter mounting bolts to make sure they're clean & tight.
If it still won't start, connect everything normally, then set up a voltmeter so its red probe is on the large red cable at the starter, and its black probe is on the starter's Aluminum housing, and the meter is where you can see it while holding the key in START. Post the reading.
Originally Posted by adrianspeeder
Relay on the fender only powers up your underhood fuse box...
No, the starter relay has nothing to do with the CJB. Both always have battery power.
