engine swap: efi -> carb
Old Jul 11, 2001 | 09:46 PM
Donate54's Avatar
im considering doing an engine swap to my truck (see sig) in the near future and i have my eye on a few 351 engines on the ford racing catalog. only thing is, they are carburated engines, and my truck has efi. what is involved in doing this swap as far as changing to carburation is concerned? am i better off just looking for a fuel injected 351? any help is appreciated!
Old Jul 17, 2001 | 12:21 PM
Ford4ever's Avatar
I have though about doing the same thing but i don't really know how easy it is to bypass the computer without changing the tranny and putting in all new gauges.
Old Jul 17, 2001 | 08:39 PM
redlariet's Avatar
Donate54
I put a warmed-up 79 302 engine in a 90 lariet. all the efi stuff fit OK. if you already have a efi 351, take off the manifolds & switch to the rebuild. I think that is easier than going carb.
Old Jul 17, 2001 | 10:20 PM
2000 F150 4x4's Avatar
Carbing it would be much easier, but you'll give up some MPG and (arguably) driveablity. I don't think the 89's used an electronically controlled tranny, so you'll be ok there. If you go EFI, you'll need larger injectors and a good free flowing EFI intake setup. I think Trickflow has a 351 designed part now. If you have a speed density system (no mass air meter, just a t/b) it probably wont work. You'll need mass air. If you have that, which I doubt, you'll need a new MAF calibrated for your EEC/injector combo. If you want mass air, FMS sells a kit for the GEN 1 L's. With that 385HP long block, you'll prolly see 350-360 EFI. It just doesn't have the top end a carb does. But it will have monster torque. If you run some long tube headers, you'll have a killer setup. Check out the Corral for tons of Winsdor info. It's mostly Mustang stuff, but it's all the same really.
